I think that building or having a local metal working company build a Franklin Stove for your permanent shelter would be great. If you are not familiar with how they work it goes like this.
THe interior of the stove is a bit bigger than normal. In side you put a baffle system the looks like this http://www.answers.com/topic/franklin-stove this is built into the interior of the stvoe. Now the way it works is like this( if you dont follow the pic on the link).
You build a fire as normal. It heats up the baffles in the back on the stove. The air in the baffle rises pulling the colder air from floor level into the baffle through the lower pipe. THe heated air is released into the room 3 to 4 feet about floor level. Or you could connect a pipe that went close to the ceiling. That way the hot air would push the cooler air lower and creat a strong circulation effect. The smoke from the wood is sucked out through the back of the stove in the normal way.
You could even heat several room this way simply by connectingducts leading to the other rooms.
I realize the pic sucks but combined with my explanation I think its fine.
