A lot more info at the link..
http://www.virtualseeds.com/seedsaving.html
Common methods of preparing your seeds:
1) Allowing the seeds to dry naturally on the plant. Corn and garlics would be a good representative of these method. Pull the corn husks when the corn as fully ripened and allow to continued drying on racks (if protected from birds and squirrels) or in paper grocery sacks indoors until they are thoroughly dried. Then you can twist them in your hands to get the kernels to fall off. Package, label with name of variety and date or year of harvest and store. For garlics, the same drying method applies. Garlics can also be braided and hung from nails, or stored in open weaved bags while they are drying. This is also referred to as "curing" when in reference to garlics. Lettuce and cole crops such as broccoli seeds can be collected directly from the plant. When you notice the seeds look dry and about ready to fall off, then you can directly pull the seeds off by hand into a waiting paper bag. How easy can that be!
2) Removing the seeds and allowing to air dry. This would be the most common methods of vegetable seed storage. For example, cucumbers and other squash type plants. Allow the fruits to fully ripen even to the point of the fruit starting to turn yellow so that the seeds inside fully develop. Then cut open the vegetable and scoop out the seeds. I would recommend a gentle washing in a mild bleach solution (one part bleach to ten parts water) and then lay out in a single layer on newspaper or paper towels until the seeds have thoroughly dried. Then store in containers of choice with appropriate labeling.
3) For bean and pea plants, again, allow the pods to ripen fully on the plant, then remove the pods, open and out pop the seeds! You will probably want to let the seeds dry out some more if they appear to need it.
4) Fermenting:
This method is needed for tomatoes as the viscous gel substance or pulp, inhibits germination so must be removed. The easiest way to do this is to slice open your tomato, squeeze the contents into a glass jar, add water up to about ¾ of the jar, stir and set aside for a few days. You will notice a icky smelly moldy residue collecting on the top of the water as well as some seeds (these are dead seeds). The water will clear and the “good” seeds will sink to the bottom of the jar. After about 4-5 days this process will seem to have come to an end, so carefully scoop out the stuff from the top and throw away, pour off the water down the sink, and then lastly, pour out the seeds from the bottom of the jar onto newspaper or paper towel for the final drying. When the seeds have dried, they can be removed from the paper and stored.
4) Fermenting:
