Mylar "space blankets" work...if you know how to use them properly
  • Mylar "space blankets" work...if you know how to use them properly
    Here are some excerpts from an excellent article about the one item that every prepper has probably bought at one time or another: the mylar "space blanket."
    A lot of the manufacturer claims about Mylar are complete hype. However, if you know how to use a Mylar blanket, they actually can help you survive.
    How to (Properly) Use a Mylar Blanket for Survival
    Mylar does not provide any insulation
    If you want to stay alive (and comfortable) with a Mylar blanket, you need to know that: Mylar does not provide any insulation.
    Yes, it will reflect some of your body heat back to you. But, if you are hypothermic, you won’t have much body heat to reflect back!
    Thus, you can’t just wrap a Mylar blanket around you like you would with a normal blanket. Instead, you need to use one of these methods to make Mylar’s reflective properties work in your favor. 1. Use Outside of an Insulating Blanket
    Mylar prevents heat loss from radiation, evaporation and (because it is windproof) convection. Traditional blankets prevent heat loss from convection and (to a lesser extent) from convection. Thus, if you combine a Mylar blanket with an insulating blanket, you will prevent all forms of heat loss.
    To do this, wrap yourself in a wool or fleece blanket. Put the Mylar blanket outside of these blankets. For even more protection, you can use duct tape to sandwich a Mylar blanket between two wool blankets. You’ll stay toasty warm this way!
    2. Create a Shelter
    One of the best uses for a Mylar blanket is to make a debris shelter. The debris acts as an insulating layer, preventing heat loss from convection. The Mylar blanket lining the shelter blocks wind and prevents heat loss from radiation.
    If it is winter and you have to make a shelter with snowy debris, the snow will start to melt as your body heat warms it up. Because Mylar is waterproof, using it to line the top of your shelter will keep the melting snow from dripping on you.
    3. Use Mylar Blanket as a Ground Sheet
    Mylar provides absolutely NO insulation. So, you can NOT just put it on the ground and expect to stay warm. The ground will suck heat right from your body.
    However, you can use Mylar as a ground sheet along with something that provides insulation (such as a bed of pine needles or other vegetation). The Mylar will help reflect some heat back towards you. Since it is waterproof, it will also protect you from wet ground.
    First put the Mylar blanket on the ground. Then pile the pine needles on top of this. The pine needles provide insulation. The Mylar blanket reflects heat back towards you. If you try to put the Mylar blanket on top of the pine needles, you’ll just end up sweaty.
    *A Mylar blanket works great when hammock camping. Put the Mylar blanket in the hammock and then put you blanket or sleeping bag on top of that. 4. Mylar Blanket Fire Reflector
    Knowing how to make a fire reflector is one of the fundamentals of survival. You set it up across from the fire. The idea is that the heat from the fire hits the reflector and bounces towards you. You’d be surprised how much warmer a fire is when you’ve got a fire reflector up.
    Most bushcraft experts show you how to make a fire reflector using logs. A Mylar blanket is even more effective as a reflector and easier to set up. 5. Mylar for Lining Your Shelter:
    In addition to lining debris shelters with Mylar, you can also use them to line other types of shelters. For example, if you are stuck in your car in winter, you can line the inside of the car with the Mylar blanket to stay warmer.
    (There is a lot more info about mylar in the article, including tips 6, 7, and 8)
    9. Lining Boots or Mittens
    If your boots get wet, cut the Mylar blanket into two squares. Put them into your boots to line them. They will keep your feet dry.
    The same also works for mittens – your hands stay incredibly warm with a layer of Mylar inside of them. Even better is if you use this layering system: Gloves, Mylar, Mittens. Tips for Using a Mylar Blanket
    • NEVER put a Mylar blanket right next to your skin. You need an insulating layer between you and the Mylar.
    • Dry the Mylar blanket before using. Since it stops evaporation, sweat easily builds up on Mylar. This will make you wet and colder. So, make sure you thoroughly dry the Mylar blanket before using.
    • Beware of rips. Mylar is very durable. However, once it punctures, it will rip easily along the puncture line. Some experts like to carry a bit of duct tape with them in case they need to repair tears.
    • Add a source of heat. If you are hypothermic, your body won’t have heat for the Mylar blanket to reflect back to you. You’ll need another source of heat. Put something like a heated rock or a flask with hot water next to you.
    Check out the article for more handy tips and illustrations, such as this:
    If your Mylar blanket doesn’t have grommets (most don’t), you can secure it to rope by putting a smooth rock in the corner and tying the rope around this
    Mylar blankets have a lot of uses other than what it was intended for. You can use them to collect rain water. I have also heard of people taking them to line a box to make a solar oven. I have not tried it but I heard it works good for heating up things like water and soup. I keep a couple in my car but also have a couple of wool blankets in car as well.
      Very informative. You could make a Mylar bag to go outside your sleeping bag and double the effectiveness of your ground sheet perhaps.
        GrizzlyetteAdams Good post, some info I was not aware of and a good tip on roping the mylar using a smooth rock.
        It is better to be a warrior in a garden, than a gardener in a war!
          I have cooked a quartered rabbit and 2 quartered sweet potatoes(all together) using the mylar in a box technique. It helps to have a dark colored pot with a clear lid(that will retain the juices) siting on a rack so that the pot is not sitting directly in the mylar box which could leech some of the heat away. It is much easier to do than to describe lol. So, you have the mylar box (usually with one side lowered for maximum sun exposure), a metal rack like from a small grill, a black stew pot with a clear lid(that is what I use, a solid black lid might work fine) and the food in the pot with a little water and whatever seasonings you like. Position the box for maximum sun exposure and give it a few hours(iirc the whole rabbit quartered and the quartered sweet potatoes were done in ~3 hours on a very sunny Florida day). YMMV
            SonofLiberty
            I love it when somebody has done a thing vs. just saying it should work. Thanks for the advice. When I visit my grand kids again, we will have to build one and test it out, maybe heating up hot chocolate (mothers may not go along with the dead rabbit part --- city girl).
              Originally posted by tmttactical View Post
              SonofLiberty
              So try a bit of pork chop, beef tips or even poultry. Remember they too are dead. Dead pig, dead cow, dead chicken.
                I have no doubt that you could cook them.
                  I saw a guy on TV use a space blanket and a round garbage can lid to make a parabolic reflector that could start a fire in just a few seconds. He was actually using it to do pyrography. (woodburning art)
                  The possibilities are endless.
                    GrizzlyetteAdams good post. I learned how not to use Mylar on a cold camping trip where he temperatures dropped well below zero. I was so glad when the sun came out
                      I use them as sunglasses for my house, cuts down on the warm from the sun during the dog days. I use warm soapy water to adhere it. Easy to remove also.
                        Plus your windows get cleaned! Seriously, That sounds like a great tip. I have a southwest window that acts like a blast furnace in the hot summer. I cover the window with an old blanket to stop the sun/heat from coming inside. Do you put the Mylar inside of the house or on the outside?
                          I put it on the inside of the outside pane, that way its reflecting the light and heat out.
                            Sort of like the tinted film you can get to put on your windows..... Cool.
                              Egg-zactly!
